NB8A fuel pressure?
timk
NB8A fuel pressure?
Postby timk » Wed Apr 01, 2015 11:04 pm
I think my fuel regulator is busted. My ECU logs fuel pressure and noticed today that my fuel pressure was at 370kPa with the fuel pump running but the engine not running.
I reviewed some old logs and it used to be 330kPa for the same scenario.
I'd like to know what another NB8A MX-5 runs at as a comparison, does anyone with an NB8A log their fuel pressure or have a gauge connected?
Alternatively if you have access to an Australian or Japanese service manual that states the pressures the fuel rail should be, that would be even better! 8)
I have a "Miata" service manual but the US spec NB8A has a deadhead system running a higher base pressure.
project.r.racing
Re: NB8A fuel pressure?
Postby project.r.racing » Thu Apr 02, 2015 8:09 am
43.5psi ??? 3 bar ???
timk
Postby timk » Thu Apr 02, 2015 10:42 am
That's using a known-good gauge and you are definitely sure you aren't running an NA reg or anything like that?
timk
Postby timk » Thu Apr 02, 2015 10:43 am
Out of interest can you note any numbers written on your reg and post them?
project.r.racing
Postby project.r.racing » Sat Apr 04, 2015 11:07 am
Pretty sure all none turbo BP engines 90-00 are 43.5psi.
timk
Postby timk » Sat Apr 04, 2015 2:41 pm
You are in Brisbane yeah? Do you mind if I temporarily hook a pressure transducer to your feed line?
Postby Magpie » Sat Apr 04, 2015 4:10 pm
Timk I can look at my logs if it would help, it is a NB engine.
timk
Postby timk » Sat Apr 04, 2015 6:42 pm
Thanks for the offer, does it have an NB8A fuel pressure regulator?
Postby Magpie » Sat Apr 04, 2015 7:32 pm
No aftermarket pressure regulator. From memory it has been very stable.
timk
Postby timk » Sat Apr 04, 2015 7:34 pm
Out of interest what base pressure do you have yours set at?
Postby Magpie » Sat Apr 04, 2015 7:53 pm
I'll check my logs when I finish at work ( a few hours)
Postby Magpie » Sun Apr 05, 2015 10:42 am
From Jap Nats fuel pressure was 43.5 psi from start to finish.
timk
Postby timk » Sun Apr 05, 2015 5:18 pm
That's relative to the intake manifold pressure I assume? Not absolute pressure.
Postby Magpie » Sun Apr 05, 2015 7:04 pm
The sensor is gauge pressure (Honeywell MLH 0-100 PSIG.C1P).
timk
Postby timk » Sun Apr 05, 2015 8:36 pm
Okay cool thanks, I assume the reference line isn't connected to the regulator then?
Sorry for all the questions but I want to get this sorted!
