Just purchased my first 1989 mx5 eunos last weekend. It didn't come with roadworthy originally, but have had it inspected and multiple areas needing fixing in the next two weeks.
Link to Rwc repair requirements: http://imgur.com/BnKCH2W
Major things needing replacement / fixing:
- Clutch slave cylinder (replacement)
- Steering rack (replacement?) - makes sounds when turning
- Seat belt replacement (replacement / fix) - no longer retracts back. It worked when i bought it. Might have pulled it too hard.
- Passenger window (fix) - automatic window works, but requires a bit of luck and patience to work. Might be issue with wiring? window regulator?
Hoping someone can help me out where I can get this work done or which of these I can attempt myself. I've done basic mechanical work on a car before, but nothing too serious. Oil flush, radiator flush, thermostat changes, gaskets, spark plugs. Hopefully that's enough to attempt some of this work?
If not, looking for a trustworthy mechanic who can fix these issues. I'm living in south eastern suburbs of Melbourne (near clayton, springvale, dandenong areas) and would prefer to drop the car off this weekend? I think the guy quoted me a bit much.
