Looking at a set of cams for my na6, wanting to know best ones available to run on a stock ecu and, can you tune the stock ecu slightly for each set of cams?
also where do i find solid lifters
all help is much appreciated.
NA6 cams
- NitroDann
Re: NA6 cams
Ecu first or give up
- beavis
- Vehicle: NB8B - Turbo
Re: NA6 cams
Zabinskii wrote:can you tune the stock ecu
You can't do a thing with the stock unit, you will have to get an aftermarket ecu
Re: NA6 cams
NitroDann wrote:Ecu first or give up
ecu it is then, cheers
Re: NA6 cams
beavis wrote:Zabinskii wrote:can you tune the stock ecu
standalone or piggy back?
- NitroDann
Re: NA6 cams
Its 2015.
Re: NA6 cams
NitroDann wrote:Its 2015.
the internat has answered my questions,
ty for the rudeness woke me up :*
- Vehicle: Non MX-5
Re: NA6 cams
and just to point out that cams chioces will be dictated by your lifter choice. so figure out the direction you wanna go with those and do lifters and cams together if going solids.
NA6 cams
Come for a troll here after the failed attempt at trolling the WRX club yesterday?
Re: NA6 cams
sailaholic wrote:Come for a troll here after the failed attempt at trolling the WRX club yesterday?
nah ahah this time im genuinely interested,
