'95 4.1 gears in '01 diff
Posted: Tue Mar 03, 2015 4:10 pm
Hey guys,
I'm looking at upgrading the diff in my NB8B (open 3.63), currently looking at getting a Kaaz clutch pack centre, but I also want to change ratios. I've found a 4.1 ring and pinion gearset from a '95 NA diff, and just wanted to double check with anyone who might know if it would be fine to put in my '01 diff?
I'm not too knowledgeable on NA diffs, but am I right in saying that all 1.8 diffs are essentially the same? I've heard bad things about the 1.6 diffs, does any of this weakness extend to the NA8 diffs, or did they basically fix them by going to the 7" size?
By the way, for anyone interested, Nengun have the Kaaz DBZ1810 for $923, which is the cheapest I've seen.
http://www.nengun.com/kaaz/basic-solid-lsd
Jack
Jack
