Normal vs se (mazdaspeed) engine mounts
mx5002
Postby mx5002 » Fri Feb 20, 2015 12:05 pm
I've read that they slightly raise the engine higher. Is this the case and by how much?
Thinking of replacing my standard ones to se ones with the added benefit of raising the exhaust ever so slightly where it touches the bracing below.
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64 :D
plohl
Re: Normal vs se (mazdaspeed) engine mounts
Postby plohl » Fri Feb 20, 2015 1:46 pm
I put them in my old car and never noticed any height difference.
plohl
Postby hks_kansei » Fri Feb 20, 2015 1:51 pm
No height difference outside of normal manufacturing tolerances to my knowledge.
if your current ones are rooted and the rubber has gone funny, then thye might raise the engine a little, but no more than just using new mounts.
If you need a few mm of clearance for an exhaust, and don't want to bend the exhaust (my recommended method) you can add a few washers to the existing engine mounts to lift the engine a little.
forcedfive
Vehicle: 10AE - Turbo
Postby forcedfive » Fri Feb 20, 2015 2:07 pm
I have just fitted the Mazda competition mounts and my mechanic said the engine is sitting higher than previously. Old mounts were 15 years old though.
10AE
WP 1:04.7 SMSP GP 1:43.0 South 1:00.8 North 1:09.8
mx5002
Postby mx5002 » Fri Feb 20, 2015 3:05 pm
Thanks guys,
Verne, are they ( the mounts) from mania?
I was looking on there eBay listing for them and it says to be wary cause the lift the engine slightly higher.
GREEN ITB'd NB8B
Marulan 47.01
green_comet
Car Detailing Guru
Postby green_comet » Fri Feb 20, 2015 3:23 pm
forcedfive wrote:I have just fitted the Mazda competition mounts and my mechanic said the engine is sitting higher than previously. Old mounts were 15 years old though.
How are you finding the Mazda competition mounts? I was looking at fitting a set in my SP.
Postby Mr Morlock » Fri Feb 20, 2015 5:11 pm
the difference between the mounts is surely going to be in the composition of the rubber i.e. a different spec. Presumably a road car has a mount which is effective at minimising NVH whereas a competition mount is less concerned about comfort but more about movement of an engine which is exposed to greater forces over a shorter time.
Postby KevGoat » Fri Feb 20, 2015 5:31 pm
There's discussions over on the Big Forum about fitting these stiffer mounts to N/A cars and the added vibration. The gains (improved shift quality is mentioned) appear to offset any minor negative.
forcedfive
Postby forcedfive » Fri Feb 20, 2015 5:53 pm
Hi Dennis,
I bought mine in the US. I have not noticed much difference in vibration or shift quality but have only dríven the car maybe 50km since fitting tham. Yet to take it in the track. The SS in a couple of weeks will be the first outing. Not sure if the SE ones are the same as what they refer to as competion mounts from 949 and Good Win.
10AE
Postby 93_Clubman » Sat Feb 21, 2015 9:02 am
forcedfive wrote:Not sure if the SE ones are the same as what they refer to as competion mounts from 949 and Good Win.
SE ones are about 35% stiffer, whereas the 949 & Goodwin comp mounts are about 40% stiffer: http://trackdogracing.com/mazdaspeedmotormounts.aspx
http://949racing.com/mazda-motor-mount.aspx
http://www.good-win-racing.com/Mazda-Pe ... -1094.html
Users browsing this forum: No registered users and 67 guests
