To oil or not to oil - 5 speed shifter turret
tasna6
Postby tasna6 » Thu Feb 19, 2015 7:49 am
Hi Everyone, Recently picked up a na6 and loving it!
I checked out the shift boots and noticed that yay the boots are fine (look new) but there is no oil and only grease lubricating the shifter. My question is - does this matter?
I suspect not, as it might have a leak and not hold any oil.
The shift action feels ok to me (though this is the only mx5 I've dríven).
Thanks for your advice!
gslender
Re: To oil or not to oil - 5 speed shifter turret
Postby gslender » Thu Feb 19, 2015 8:22 am
It is supposed to have oil. That's what mazda expected when they designed it - if you do something different you'd need to be aware of why. I'd put oil in it.
Postby 93_Clubman » Thu Feb 19, 2015 10:13 am
Yeah, factory workshop manual states 'oil' for turret - manga_blue posted a page from it on here a while back on another GB issue, & the page clearly stated oil.
beavis
Postby beavis » Thu Feb 19, 2015 3:27 pm
it needs oil
Get something that is GL4 75-90
tasna6
Postby tasna6 » Thu Feb 19, 2015 7:47 pm
Cheers everyone, I'll give it a splash when I change the gearbox oil and monitor the levels.
pezchops
Postby pezchops » Thu Feb 19, 2015 7:53 pm
check how much oil drains from your gear box.
if more oil drains out than should be in there you can deduce the turrent oil has leaked into the gearbox
i dont know how much oil is suppose to be in the turrent...maybe not enough to measure if it has leaked into the gearbox?
greenltd
Postby greenltd » Fri Feb 20, 2015 4:49 am
Yes there should be oil in there, but the seals may be worn hence the grease as a substitute. It volume of oil is small, perhaps 50ml from memory. Mine ised to leak and drain completely in a few days of driving so i used special molybdenum grrase. My experience says it worked well keeping a great feel to the shift action.
aka_juffa
Postby aka_juffa » Fri Feb 20, 2015 9:01 am
Just to add some information regarding the turret oil leaking into the gearbox.
http://forum.miata.net/vb/showthread.php?t=224652
Go the last post (page 2)....interesting read.
J.
Postby 93_Clubman » Tue Mar 31, 2015 10:57 am
No wonder couldn't find it - It was MrRevhead not manga_blue that posted the page:
MrRevhead wrote:Image
