NC Lifter noise
*DAN*
NC Lifter noise
Postby *DAN* » Wed Feb 04, 2015 5:36 pm
Hey guys,
I've just completed an oil change on my NC and have noticed a noisy lifter-like noise coming from the engine bay on cold starts. Don't know if my memory is playing up but I've only seemed to have noticed the noise after the oil change. I put 10w-40 penrite and used an OEM oil filter for the change. my bad if this has been covered already, I've done a search and couldn't find anything relating the the NC model specifically.
project.r.racing
Re: NC Lifter noise
Postby project.r.racing » Wed Feb 04, 2015 6:20 pm
solid lifter. before and after oil change wont make a difference.
you put in 4.5L right?
JBT
Re: NC Lifter noise
Postby JBT » Wed Feb 04, 2015 8:07 pm
It could be the VVT actuator. Listen to this https://www.youtube.com/watch?v=2mBIh6ONVDw
Google NC MX5 VVT actuator for heaps of hits.
*DAN*
Re: NC Lifter noise
Postby *DAN* » Thu Feb 05, 2015 7:41 pm
Yep 4.5L put in.
May be the VVT, mine definitely doesn't sound as severe as some of the ones that are on the internet. Seems to be intermittent though, cold start this morning sounded fine and car drives a lot better than it did before after changing fuel. Low end was feeling slightly sluggish before but feels fine now. Will update if it comes back tomorrow morning
JBT
Re: NC Lifter noise
Postby JBT » Thu Feb 05, 2015 8:34 pm
The serpentine belt tensioner pulley and idler pulley can also rattle intermittently and can be heard at idle. I had to replace mine at 65,000km.
*DAN*
Re: NC Lifter noise
Postby *DAN* » Sat Feb 07, 2015 3:02 pm
It could be that, sounds a lot more likely than a VVT actuator. Will have to have another listen on the next cold start. How much did it cost to replace yours if you dont mind me asking?
JBT
Re: NC Lifter noise
Postby JBT » Sat Feb 07, 2015 7:25 pm
It cost me $332 for the parts (tensioner $220 and idler $112) and I fitted them myself. Easy to do once you get the battery out of the way.
DIY is here: http://mx5cartalk.com/forum/viewtopic.php?f=79&t=54540
Users browsing this forum: No registered users and 84 guests
