Are Na6 diff shaft seals the same NA6CE VLSD seals?
M1474
Vehicle: ND - Turbo
Postby M1474 » Mon Jan 26, 2015 2:34 am
The alloy rear cover/hanger was smashed on my eunos VLSD. Will my ADM 1.6 seals be ok with the VLSD stubs?
Cheers.
GHETTOCET
The American
Re: Are Na6 diff shaft seals the same NA6CE VLSD seals?
Postby The American » Mon Jan 26, 2015 8:20 am
I thought you'd upgraded to the 1.8 rear? Isn't there a pile of steam pipe and other bits at your place that wants to munch on 1.6 diffs?
Postby hks_kansei » Mon Jan 26, 2015 3:23 pm
Measure the stub diameter with a pair of verniers, if they're the same size the seals should be fine.
M1474
Vehicle: ND - Turbo
Postby M1474 » Wed Jan 28, 2015 3:58 pm
Thanks guys, I didn't have the VLSD with me.
They are the same size.
T Am, not for the Malibu, an exciting new lightweight joint project with Rosco.
GHETTOCET
The American
Postby The American » Wed Jan 28, 2015 8:13 pm
Sounds fun, I'll keep an eye peeled for the build thread!
speed
Postby speed » Fri Jan 30, 2015 10:12 am
Good to see s few joint projects going on. I will also keep an eye out for the build thread :)
