Help!!! I broke down
squibbward
Postby squibbward » Sat Jan 17, 2015 8:19 am
So driving today and get about 2 hours down the highway at about 115km/h and out of no where the engine cuts out no sputtering no battery drain just cruising then nothing no acceleration nothing. So i pull over shut the car completely off thinking it overheated it cools down go to start it and nothing. The lights come on the starter whirrs away but the engine does not crank.
My thoughts us possibly the altenator locked up and went out
Or the timing belt jumped timing
Or the flywheel is trashed out
I will say timing belt is only 5000ks old so still new and all the other belts are intact and tight. So lmk what it might be so i can test it when i get to the garage
squibbward
Re: Help!!! I broke down
Postby squibbward » Sat Jan 17, 2015 8:27 am
Also on the bright side after i broke down a man in a truck kindly gave me a tow to a parking lot that happened to be where the worlds largest rocking chair is Image
luzinit
Postby luzinit » Sat Jan 17, 2015 9:06 am
Could possibly be EGI relay? Sounds like similar symptoms. If it is, you could short two of pins to get the ignition circuit going and car started. Do a quick search for EGI relay and you will find a thread that mentions it. Hope that helps
squibbward
Postby squibbward » Sat Jan 17, 2015 3:33 pm
So may be a bigger problem then the relay i bump the starter and the crank pulley turns but the timing belt and cam gears do not turn at all
So did it jump timing in bend the valves if so that is gonna suck or is something else broke inside maybe a broken cam shaft?
pezchops
Postby pezchops » Sat Jan 17, 2015 4:10 pm
are you 100% sure the timing belt is still there?.
everything you mention is exactly what happens if the timeing belt is off or slipped teeth from a buggered tensioner.
you said when you tried to re-start ,the engine didnt crank?..maybe you mean it turns over but doesn't fire??
just take it who ever did your belt and get them to look at...no harm done to your motor ,its non-interference.
Postby bruce » Sat Jan 17, 2015 5:05 pm
The cause of the problem is your steering wheel - it's on the wrong side.
Postby bruce » Sat Jan 17, 2015 5:06 pm
Why do you talk in kilometers and then post a picture from America?
squibbward
Postby squibbward » Sat Jan 17, 2015 5:20 pm
I was trying to be nice to people around the world and yes i know my timing belt is 100% there i.e. exposed cam gears and belt[IMG]http://tapatalk.imageshack.com/v2/15/01/16/21d3156f8784a27d6292d8a4e29b0a10.jpg[IMG]
Postby Magpie » Sat Jan 17, 2015 6:37 pm
Word of the day - CAS it it working?
davekmoore
Postby davekmoore » Sat Jan 17, 2015 7:06 pm
squibbward wrote:........ the starter whirrs away but the engine does not crank ......
Your starter motor is not connected to your motor or is otherwise broken. Dunno why that would have stopped your motor running though. EFI relay failure will not stop the motor cranking but will stop if firing.
squibbward
Postby squibbward » Sun Jan 18, 2015 11:48 am
I concede i was wrong and you all were right the timing belt was loosened and stripped right against the crank gear so a new timing belt and tensioner later i am a happy miata owner again thanks you all for helpingImage
greenMachine
Postby greenMachine » Sun Jan 18, 2015 12:24 pm
You might want to do something about that a/c compressor too ....
davekmoore
Postby davekmoore » Sun Jan 18, 2015 12:43 pm
Good to hear the solution was simple.
greenMachine
Postby greenMachine » Sun Jan 18, 2015 5:01 pm
greenMachine wrote:You might want to do something about that a/c compressor too ....
:oops: power steer pump actually ...
:mrgreen:
squibbward
Postby squibbward » Sun Jan 18, 2015 6:24 pm
Yeah its hooked back up now i undid the"wrong" bolt to loosen it but it made it move more then the adjustment bolt for it so i wasn't too concerned but i took her out for a drive tonight and she is running great even better then before and the rpms are less too what used to be 4000 is now 3800 so that's good
