Have I Stuffed a Perfectly Good Radiator?
Roadrunner
coyotes after you
Postby Roadrunner » Wed Dec 03, 2014 8:01 pm
Replaced my SE radiator with the recommended Koyo.
I installed yesterday and burbed the system but got late so left all as it was.
Got home today and theres a steady consistant drip from under the car!!!
As it turns out when I dropped the new unit in its dragged along a screw sticking out on the condensor and bent the fins :evil:
even more annoying is as far as I can see these screws on the condensor arent even used for anything!
As soon as I saw the core I saw the issue:
Its leaking steadily from here:
Is this stuffed? Is it fixable?
I feel sick :(
MeepMeep
Roadrunner
coyotes after you
Re: Have I Stuffed a Perfectly Good Radiator?
Postby Roadrunner » Wed Dec 03, 2014 8:07 pm
The offending screw:
MeepMeep
Postby bruce » Wed Dec 03, 2014 8:32 pm
Just straighten the fins yourself.
A radiator place should be able to put a blob of solder in that in that broken bit.
Roadrunner
coyotes after you
Postby Roadrunner » Wed Dec 03, 2014 8:58 pm
Iv been googling radiator repairs, but in reality how will this hold up in the long run? With the odd track day be ok or is this just a temp few month fix?
MeepMeep
Postby Mr Morlock » Wed Dec 03, 2014 9:11 pm
the advice is correct- take it to a local or convenient radiator specialist and ask them for advice. If you don't repair it then you buy another radiator.
Nevyn72
Postby Nevyn72 » Wed Dec 03, 2014 9:14 pm
Bummer dude, I know what I would do but you're not going to like the answer....... :|
Take it into a radiator repair shop and see what they say, they will have a better idea of what's possible and how durable it will be.
Balance the cost of the repair with the cost of replacement and a 'peace of mind' factor.
Must admit, as soon as I saw your image I dashed down to the garage and peered around the foam baffles on my radiator to make sure I didn't do the same sort of damage when installing my Koyo!
Mercifully mine is all good......
The American
Postby The American » Thu Dec 04, 2014 8:29 am
From past experience, they will take out that one fin, top and bottom. Makes a durable repair, and it's a very small fraction of the overall device.
speed
Postby speed » Thu Dec 04, 2014 8:35 am
Man that sucks. The repair will probably be stronger so I wouldn't worry about durability.
Roadrunner
coyotes after you
Postby Roadrunner » Thu Dec 04, 2014 2:15 pm
Dropped it off this morning at a local radiator place.
The guy was pretty genuine, said he straightens everything out, uses a weld that goes hard as and he uses a vacuum system thing that sucks the weld inside the hole too so its a really good bond.
Pressure tests everything as well and said while it won't look pretty, it will last longer than the radiator.
$40 all up im stocked if its as good as he says!
MeepMeep
Postby bruce » Thu Dec 04, 2014 2:36 pm
Good stuff. Easy peaay for radiator guy. Cheap as.
speed
Postby speed » Thu Dec 04, 2014 4:03 pm
Nice!
