What Cylinder Mead cc's ????
Posted: Sun Nov 23, 2014 5:23 pm
by DarrylA
Hi guys
Can anyone tell me what cc's I need in my cylinder head chamber to achieve a compression ratio of 10.5-1, and 11-1.
Head is a BP4W.
Many thanks
Re: What Cylinder Mead cc's ????
Posted: Sun Nov 23, 2014 5:43 pm
by Magpie
http://www.csgnetwork.com/compcalc.htmlHowever you can adjust the head gasket thickness instead, depending on what you have already done to your engine.
Posted: Sun Nov 23, 2014 6:09 pm
by manga_blue
OEM head gaskets are around 40 thou. Victor Reinz gaskets from mx5parts.co.uk are the cheapest high quality thin gaskets at 30 thou. You can take 60 thou off the head. You can swap to NB8B pistons for an extra 0.5 in CR. etc etc. Try googling chamber volume or piston crown volume on miata.net. Plenty of ideas there.
Posted: Mon Nov 24, 2014 4:36 pm
by project.r.racing
you wont find those compression ratios by machining the head. you can get about 0.2 extra compression. buy pistons instead.
