What Cylinder Mead cc's ????
DarrylA
Postby DarrylA » Sun Nov 23, 2014 5:23 pm
Hi guys
Can anyone tell me what cc's I need in my cylinder head chamber to achieve a compression ratio of 10.5-1, and 11-1.
Head is a BP4W.
Many thanks
:NB8A:
Re: What Cylinder Mead cc's ????
Postby Magpie » Sun Nov 23, 2014 5:43 pm
http://www.csgnetwork.com/compcalc.html
However you can adjust the head gasket thickness instead, depending on what you have already done to your engine.
Postby manga_blue » Sun Nov 23, 2014 6:09 pm
OEM head gaskets are around 40 thou. Victor Reinz gaskets from mx5parts.co.uk are the cheapest high quality thin gaskets at 30 thou. You can take 60 thou off the head. You can swap to NB8B pistons for an extra 0.5 in CR. etc etc. Try googling chamber volume or piston crown volume on miata.net. Plenty of ideas there.
project.r.racing
Postby project.r.racing » Mon Nov 24, 2014 4:36 pm
you wont find those compression ratios by machining the head. you can get about 0.2 extra compression. buy pistons instead.
