speedo fix done today on 2 NB's
Silvia
Postby Silvia » Tue Oct 14, 2014 6:46 pm
A mate and I with a 2002 and 2004 did the "speedo fix" today, successfully it seems.
viewtopic.php?f=57&t=62536&start=30 was our guide and made it possible for a pair of non mechanics to fix their own onandoff speedos. (not the bathers!)
Many thanks to roadrunner for his Garage article we used. :beer:
Suggest you mention blocks to lift front wheels as even with the rear raised high room was tight under the gearbox area.
Also a tiny soldering iron is best - it's pretty delicate getting the two wires soldered into those small notches to fix the problem.
Took about an hour each car. :D
Silver Nomad
2002 NB8C
Roadrunner
coyotes after you
Re: speedo fix done today on 2 NB's
Postby Roadrunner » Tue Oct 14, 2014 10:03 pm
8) glad it helped you out. Good idea about raising the front a bit too :DIY:
Hope you didn't spill much gearbox oil, the smell will linger for days :wink:
MeepMeep
Silvia
Postby Silvia » Wed Oct 15, 2014 7:42 am
No spilled oil at all.....but Redline MT90 gearbox oil only has the smell of efficiency anyway :roll:
Silver Nomad
2002 NB8C
