Oil Filter Stud / Nipple
Posted: Fri Oct 03, 2014 12:20 pm
by madjak
Anyone happen to know the actual name / part number for the M20 stud that the oil filter screws on to?
Oil Filter Bolt
Oil Filter Stud
Oil Filter Nipple
All result in not very helpful searches...
Re: Oil Filter Stud / Nipple
Posted: Fri Oct 03, 2014 12:38 pm
by madjak
Found it!
E5B6-10-319C
Official name: Joint
Posted: Fri Oct 03, 2014 12:45 pm
by manga_blue
Really, relly hard to tell from the parts catalogue, but it looks like Mazda part no B630-10-319 "Joint". Listed in 1030 Cylinder Block in http://www.miata.net/garage/90-99Parts/ ... ENGINE.pdf
Posted: Fri Oct 03, 2014 4:00 pm
by madjak
Does anyone happen to have a spare "joint" lying around for a 1995? :D
Posted: Fri Oct 03, 2014 4:37 pm
by project.r.racing
careful where you get them from if getting a used one. as they are different lengths depending on what engine it came from. some are longer for water to oil coolers. some are shorter for smaller filters.
Posted: Fri Oct 03, 2014 5:53 pm
by 4sfed5
plumbing suppliers will sell you 20mm nipples in various lengths
Posted: Fri Oct 03, 2014 6:16 pm
by madjak
I'm putting on a sandwich plate for an oil cooler which has its own threaded nut. I did find a shorter one but it listed it as NA 90 - 94. I'll pull one out of my 1.6 and see if it fits. Can they go in to far?
