Oil Filter Stud / Nipple
madjak
Postby madjak » Fri Oct 03, 2014 12:20 pm
Anyone happen to know the actual name / part number for the M20 stud that the oil filter screws on to?
Oil Filter Bolt
Oil Filter Stud
Oil Filter Nipple
All result in not very helpful searches...
madjak
Re: Oil Filter Stud / Nipple
Postby madjak » Fri Oct 03, 2014 12:38 pm
Found it!
E5B6-10-319C
Official name: Joint
Postby manga_blue » Fri Oct 03, 2014 12:45 pm
Really, relly hard to tell from the parts catalogue, but it looks like Mazda part no B630-10-319 "Joint". Listed in 1030 Cylinder Block in http://www.miata.net/garage/90-99Parts/ ... ENGINE.pdf
madjak
Postby madjak » Fri Oct 03, 2014 4:00 pm
Does anyone happen to have a spare "joint" lying around for a 1995? :D
project.r.racing
Postby project.r.racing » Fri Oct 03, 2014 4:37 pm
careful where you get them from if getting a used one. as they are different lengths depending on what engine it came from. some are longer for water to oil coolers. some are shorter for smaller filters.
4sfed5
Postby 4sfed5 » Fri Oct 03, 2014 5:53 pm
plumbing suppliers will sell you 20mm nipples in various lengths
madjak
Postby madjak » Fri Oct 03, 2014 6:16 pm
I'm putting on a sandwich plate for an oil cooler which has its own threaded nut. I did find a shorter one but it listed it as NA 90 - 94. I'll pull one out of my 1.6 and see if it fits. Can they go in to far?
