NB8A won't start
wyrdeman
NB8A won't start
Postby wyrdeman » Tue Sep 23, 2014 6:49 pm
OK, this me has me stumped and I would really like some suggestions.
I have a 2000 model NB8A. Last week it wouldn't start, although it cranked over as normal, just no starting.
I have followed a number of guides to diagnosing the problem and, so far, everything passes the tests.
One thing that I noticed was that the tacho didn't move when cranking and that lead me to think of the cam sensor and the crank sensor.
I pulled them and tested both. Both appeared to work, although the crank one only gave about 0.75V when metal passed near it. I swapped this (the crank sensor) out.
There is still no starting. Just cranking, with no tacho movement. I should probably add, no spark.
So, any advice?
Nick
shuey
Re: NB8A won't start
Postby shuey » Tue Sep 23, 2014 6:52 pm
Is that after you have dríven it for awhile or starting up when cold?
wyrdeman
Postby wyrdeman » Tue Sep 23, 2014 6:55 pm
Well, it was after the car had been left for about 4 hours. So it was cold.
I can still not start it after another 4 days of the diagnostics and getting parts.
Nick
Postby bruce » Tue Sep 23, 2014 7:07 pm
Fuel?
Got some?
wyrdeman
Postby wyrdeman » Tue Sep 23, 2014 7:22 pm
Yes, lots of fuel.
OK, the diagnostics.
Immobiliser isn't the problem (light flashes and goes out)
Checked the timing belt isn't broken.
Check engine light doesn't light up when the ignition is turned on.
Checked the main EIF relay (green one in the engine bay)
Checked the relays under the dash and checked that I get 12V to the ECU (pin a1)
Fuel pump relay is fine.
Fuel pump runs.
Changed the fuel filter.
Fuel tank has lots of fuel (>40l)
Fuel comes though the lines.
No spark from any plug.
Checked all the fuses under the dash and in the engine bay.
Nick
JBT
Postby JBT » Tue Sep 23, 2014 8:07 pm
Lack of ignition (spark) assuming plugs are OK and ignition power is getting to fuel pump etc.: fuses, coils, leads, CAS, wiring detached.
Postby Mr Morlock » Tue Sep 23, 2014 10:39 pm
In the good old days and even with things like lawn mowers probably the first thing to check is spark. It will not be plugs.
Postby Okibi » Wed Sep 24, 2014 12:01 am
My NB8A also has some fuses right up under the dash near the steering column, I think they're used by the alarm. Might also help to check those.
greenMachine
Postby greenMachine » Wed Sep 24, 2014 12:28 am
Cam sensor?
Crank sensor?
Easiest way is to borrow someone else's sensor and swap for yours, starting with cam sensor, then crank.
:mrgreen:
Postby Magpie » Thu Sep 25, 2014 9:42 am
Buy a noid light and plug it into an injector. No light no injector signal, possible failed can angle sensor! Are the plugs wet with fuel when you crank?
Noid lights are cheap and a quick way to diagnose or eliminate a problem.
http://www.tridon.com.au/Products/Product.aspx?SG=5&S=21&G=622&P=68586
Postby Mr Morlock » Thu Sep 25, 2014 10:30 am
Reread Nicks list- the problem is no spark- he listed it.
luzinit
Postby luzinit » Thu Sep 25, 2014 4:37 pm
EGI/Main relay? It's the green one in the engine bay fuse box.
Cort500
Postby Cort500 » Thu Sep 25, 2014 4:57 pm
I had same problem in mine a few months ago. I changed the crank angle sensor and seemed to fix it but it started doing similar things only a little while later. Replaced cam sensor and its been fine ever since. I did also buy a new EGI relay but it made no difference to my car.
It's the wife's car.
Postby Mr Morlock » Thu Sep 25, 2014 8:43 pm
How can an engine run without spark?
gslender
Postby gslender » Thu Sep 25, 2014 10:03 pm
Mr Morlock wrote:How can an engine run without spark?
A diesel engine can.
