Power steering AC accessory belt - tension, alignment
Posted: Sat Sep 13, 2014 4:56 pm
As mentioned a week or so ago, during a commute the Jaffa threw of its power steering/AC accessory belt, something I discovered up hill on Sandgate Road through the corners at Albion. I managed to secure a replacement belt (although subsequently discovered the rejected belt had been neatly deposited on the engine undertray) and on getting home set about fitting the new belt.
I wouldn't consider myself particularly mechanically inclined but would put replacing an accessory belt well within my capabilities. I did do a little digging, and come across this document (http://www.miata.net/garage/Miata%20NB%2099-05%20Belt%20Guide.pdf) which pretty much confirmed what I expected.
So, job seemed easy enough, but didn't seem to be able to wind on enough tension on to the belt before running out of adjustment, and noticed the adjustment bolt (the long one, 12mm, M8, probably 75mm or so long) was slightly bent, with some of the thread flattened. Went for a drive, a bit of squealing, got home, opened the bonnet, belt had slipped out (towards the nose) two notches on the main pulley and the airconditioner pulley, but was fully secure on the power steering pulley.
Tried it again today, this time focussing on the right order of tightening bolts. Managed to snap the adjustment bolt. Went out, got another one. Ran through the process again (I'm totally across it now), this time the adjustment bolt's pretty much tight without all the thread being used. Belt's still loose for my liking. Go for a drive, no squealing this time but belt has slipped two notches on the main pulley and the airconditioning pulley again, sitting correctly on the power steering pulley.
So, wondering if anyone had any thoughts. I'm wondering if the power steering pump's not sitting where it should be, given it seems to be the one pulling the belt out of line. Aircon and P/S are working fine.
