Oversized oil filter
davekmoore
Postby davekmoore » Fri Sep 12, 2014 10:04 pm
This is the filter on top of my relocation kit. Any thoughts on the correct replacement? It's taller than a standard one. The writing on top says WZ442 but I can't find any reference to that anywhere. There's also room to go taller again.
Re: Oversized oil filter
Postby manga_blue » Fri Sep 12, 2014 10:34 pm
Same mounting as stock.
davekmoore
Postby davekmoore » Fri Sep 12, 2014 11:05 pm
So if I get a Ryco Z7148A I'll be right!?
Postby manga_blue » Fri Sep 12, 2014 11:06 pm
Z148A. Works on mine.
Postby bruce » Sat Sep 13, 2014 9:55 am
That's what I've got too on the sr20.
Postby Mr Morlock » Sat Sep 13, 2014 12:12 pm
go to Bursons or a oil supplier and they will tell you. Its probably only longer to get easier access. Bigger filters are not a sign that filters are better and generally older cars had bigger filters - generalisation.
Postby manga_blue » Sat Sep 13, 2014 12:23 pm
They sell Ryco Z148A filters for Mazdas at Bursons. :wink:
tbro
Postby tbro » Sat Sep 13, 2014 12:34 pm
Dave
Thats a Nissan filter, using a relocated filter unit means that you won't use a Mazda filter.
Z442 ryco suits Nissan Silva, WZ442 is a Wesfil brand, PLEASE use the ryco or genuine Nissan.
Terry
emily_mx5
Postby emily_mx5 » Sat Sep 13, 2014 12:53 pm
aside from easier access maybe, is there any benefit to using a larger filter ?
Black_Penguin
Postby Black_Penguin » Sat Sep 13, 2014 12:55 pm
I believe the theory is they have a greater surface area so don't clog as fast as smaller one.
Postby Danny » Sat Sep 13, 2014 1:11 pm
Wouldn't a smaller filter creates less of a pressure drop and larger is better if filter changes are missed or happen less often?
Anybody done a pressure comparison?
sailaholic
Postby sailaholic » Sat Sep 13, 2014 1:14 pm
Larger filter surface area should mean less restriction at the same flow.
A thicker filter element for the same surface area would have a greater pressure drop.
Postby manga_blue » Sat Sep 13, 2014 1:15 pm
Larger filters have larger filtration area, reduced flow restrictions, longer life and lower risk of blockage but they can take longer to pressurise which may affect start-up lubrication (including HLA pressurisation if you drive an NA with old lifters). Size doesn't significantly affect cost. What Mazda have tended to do is to fit the largest filter they can. Space restrictions on some motors/manifolds have been the main restriction. The Z148A is standard size for a 121 (among many other larger Mazda donks).
davekmoore
Postby davekmoore » Sat Sep 13, 2014 7:37 pm
tbro wrote:Dave
Terry
This'll be right then?
http://www.ebay.com.au/itm/Ryco-Oil-Fil ... 338d7f234f
By the way, the position of the relocation kit means there's virtually no restriction on how tall a filter would fit. My understanding is also that bigger means less restriction?
project.r.racing
Postby project.r.racing » Sat Sep 13, 2014 8:12 pm
sailaholic wrote:Larger filter surface area should mean less restriction at the same flow.
but the hole to and from the block to the filter is the same size?
