Page 1 of 18
US Headers & Exhausts NA
Posted: Thu Aug 14, 2014 5:30 am
by Dupain
Do they bolt straight on to our stock catalytic converters?
Re: US Headers & Exhausts NA
Posted: Thu Aug 14, 2014 9:40 pm
by aka_juffa
Yes, but you should make sure that you confirm your exact model with the seller as there can be some variation.
J
Posted: Thu Aug 14, 2014 9:59 pm
by Apu
There are so many good options locally, why go through the hassle of getting it in from the States?
Posted: Thu Aug 14, 2014 10:12 pm
by Dupain
Thanks J. They are very cheap Apu, and shipping is ok. Just after a 4-1 header and most are 4-2-1.
Posted: Thu Aug 14, 2014 11:16 pm
by ralt
Hi.
Just remember most US extractors are to a degree compromised owing to the steering shaft on the left hand side ( the hot side )on Na & Nb and the problems with long primaries and collectors in a restricted space, You would be better off getting onto one of the buying groups and buy from yahoo japan secondhand or source locally.
Posted: Fri Aug 15, 2014 9:13 am
by Dupain
ralt wrote:Hi.
Thoughts are that a RHD header into a LHD car like you said would be a problem and a LHD header into a RHD with the steering shaft now on the left hand side would be ok with the extra room.
Some of these US headers go for $120 US, I suppose they have a bigger market.
Posted: Fri Aug 15, 2014 9:22 am
by Dupain
Posted: Fri Aug 15, 2014 10:08 am
by plohl
http://www.ebay.com.au/itm/CXRacing-Header-1989-1999-Miata-MX-5-NA-1-8L-Equal-Length-2-pcs-Vband-/271543748288?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f3944c6c0Those aren't equal length. At all. You can tell by looking at cyl 1 and cyl 4. Cyl 1 should be reasonably straight to the collector, and 4 would be curled up to make up the length. You should have spent you're money fixing the current headers.
Posted: Fri Aug 15, 2014 11:12 am
by Dupain
Posted: Fri Aug 15, 2014 11:29 am
by plohl
Do you even understand what tuned means?
Posted: Fri Aug 15, 2014 11:31 am
by Regie
No warranty aye.
I see these welds lasting a long time
Posted: Fri Aug 15, 2014 11:55 am
by slug_dub
SURE ARE CURLY.
Posted: Fri Aug 15, 2014 3:57 pm
by Dupain
plohl wrote:Do you even understand what tuned means?
Gas flow rates to the collector from each outlet. Arrive same time.
Posted: Fri Aug 15, 2014 4:04 pm
by Steampunk
"Product Info and Spec:
Header:
1.65" Equal Length Runners"they have a rather broad definition of "equal length".
Primary that should be the shortest is the longest and vice-versa.
Also, how exactly does the secondaries attach to the tertiary?
Posted: Fri Aug 15, 2014 4:07 pm
by Dupain
I'll go a review when I get it.
Don't brush it off because it is cheap and on E Bay. CX Racing has a huge range of products.
The more common 4-2-1 can go for $120.
