Page 1 of 2
Painting Valve Cover
Posted: Fri Jul 25, 2014 11:59 pm
by Dupain
Would you advise to get a new gasket or use the old one to reinstall after painting?
Re: Painting Valve Cover
Posted: Sat Jul 26, 2014 12:05 am
by manga_blue
Depends how old the gasket is. A supple relatively new one can be re-used. A brittle old one usually can't.
Only use genuine Mazda for this. This is one case where genuine is far better than aftermarket. Best source is here: http://www.mx5parts.co.uk/cover-gasket- ... p-240.html Make sure you select 1.8 or 1.6 correctly - they're different.
Posted: Sat Jul 26, 2014 2:45 am
by Dupain
Thanks. Will get one.
Posted: Sat Jul 26, 2014 10:54 am
by booerns
Mine was in relatively good condition however a close friend of mine still recommended using a bit of gasket goo on the corners of the cams at the front and corners of the rear cas - apparently these are common places to leak. I'm not sure if it was necessary in my case but am happy to report not a single leak.
Posted: Sat Jul 26, 2014 11:58 am
by manga_blue
Like this? :wink:
Posted: Sat Jul 26, 2014 12:07 pm
by booerns
Haha yep exactly like that. Where'd you source it from?
Posted: Sat Jul 26, 2014 12:17 pm
by manga_blue
Mazda factory workshop manual. Go looking in the technical guides section of this forum.
Posted: Sat Jul 26, 2014 12:42 pm
by booerns
Yeah that probably would've been a good place to start haha. Cheers
Posted: Thu Aug 07, 2014 12:48 am
by Dupain
All painted. Waiting for the gasket to arrive and need to also buy some sealant. Covers are around $40-50 2nd hand. Would love to also do one in fluro lime green or fluro pink.
Not shaving.
Posted: Thu Aug 07, 2014 1:05 am
by Dupain
Covers are pretty cheap @$40-50.
Amazing design with balanced uniform lines and size.
Working on an art project with these covers. Maybe get two or three and paint them (most likely using stencils) and frame it.
Posted: Thu Aug 07, 2014 1:38 am
by Okibi
Looks pretty good, gonna paint mine soon too.
Posted: Thu Aug 07, 2014 2:08 am
by booerns
Love the red!
I went for something a bit more obnoxious :grin:Image
Posted: Thu Aug 07, 2014 2:32 am
by Dupain
Love the white and blue too. To be honest, I'm hopeless with the details which is why I'm not shaving or colour the letters.
Give is a few very fine coats rather than one thick coat. The Honda Forum boys have a lot of advice on how to do this.
Just sourcing wrinkle paint other than red or black is difficult.
Posted: Sat Aug 23, 2014 7:53 pm
by Dupain
Installed the gasket this afternoon.
Gasket looks like a thong.
Snug fit.
Posted: Sat Aug 23, 2014 8:09 pm
by Lokiel
Turned out great but please re-consider painting the lettering and do them black.
Also, you shouldn't paint hose barbs, it makes fitting hoses a bit harder and you risk getting paint flakes in the hose.
