NB SE - Leaking Water Pump - Help/ideas *video*
Posted: Wed Jul 09, 2014 7:59 pm
by prolifik
Hey guys... any ideas where this may be coming from...
Going to have to strip it down... Timing belt was done a week ago.
http://youtu.be/5uALZMuLjak
Re: NB SE - Leaking Water Pump - Help/ideas *video*
Posted: Wed Jul 09, 2014 8:45 pm
by emily_mx5
just looks like the waterpump outlet gasket hasnt sealed properly. You can unbolt the flange and replace the gasket, make sure to use some hi-temp "gasket goo" to help the seal.
Posted: Thu Jul 10, 2014 11:40 am
by 93_Clubman
prolifik wrote:Timing belt was done a week ago.
Was the water pump also replaced when the timing belt was done?
Posted: Thu Jul 10, 2014 10:33 pm
by prolifik
Yea, water pump as well.
I guess ill have to pull everything off again :-(
Posted: Sun Jul 13, 2014 12:14 pm
by prolifik
Seems all sorted.... I just put a bunch of gasket goo in between the return pipe where u could see it dropping out from.
Seems to of worked.
But now I get a p0031 cel! Omgggggg
Didn't even touch the 02 sensor..... Is there any checks I can do before replacing?
Thanks for help guys.
Posted: Sun Jul 13, 2014 1:07 pm
by 93_Clubman
O2 sensor can be tested using a multimeter, but don't know what values you should see on the NB SE sensor. Personally I'd reset the ECU by disconnecting the battery & pumping the brake pedal a few times, & see if it replicates the code, as sometimes after doing major maintenance codes can be thrown until things settle.
Posted: Mon Jul 14, 2014 10:41 am
by prolifik
Yea. I'll try i
Just very weird all of a sudden, especially since you only touch with that connector to remove the rocker cover
