DIFFERENT ENGINE NOTE???
OR31LLY
Postby OR31LLY » Mon Jun 30, 2014 9:11 pm
I just put my NA6 in for a service and a tune up as it was running like dog balls.
I get it back, and the whole car under accelleration sounds much more growly instead of smooth and linear...
Is this a possible advance in timing?
Can a simple "tune" do this???
The exhaust note has changed to. I had a fairly raspy exhaust at a certain rpm, and now it hardly does that.
Can anyone explain?
aka_juffa
Re: DIFFERENT ENGINE NOTE???
Postby aka_juffa » Mon Jun 30, 2014 9:32 pm
New air filter?
Engine is breathing better and sounds more forty.
J
marty085
Postby marty085 » Mon Jun 30, 2014 10:29 pm
Rorty?
emily_mx5
Postby emily_mx5 » Mon Jun 30, 2014 10:37 pm
It's not a carby... No such thing as a "tune"
sailaholic
Postby sailaholic » Mon Jun 30, 2014 11:04 pm
Not true Emily. Timing and plug gap are part of a "tune up service" and still apply here.
speed
Postby speed » Tue Jul 01, 2014 9:41 am
Just changing a coolant sensor changed the note of my car.
Postby 93_Clubman » Tue Jul 01, 2014 10:52 am
Assuming still standard, have they refitted the airfilter element &/or the airbox snorkel up to the rear pside corner of the engine bay? Or have they possibly removed an old cloth that had been sucked into the airbox snorkel (that's what I found in the airbox snorkel of my old NA6 just after I bought it).
project.r.racing
Postby project.r.racing » Tue Jul 01, 2014 11:48 am
running like dogs balls. now running like it should. so the air-fuel ratio has changed. hence diffence in exhaust sound due to combustion being different.
chrisearl88
Postby chrisearl88 » Tue Jul 01, 2014 12:36 pm
Also could have replaced a gasket or fixed a small exhaust leak which would change the sound.
lizard
Postby lizard » Tue Jul 01, 2014 1:03 pm
speed wrote:Just changing a coolant sensor changed the note of my car.
Now I have heard everything :roll:
CapitalF
Postby CapitalF » Tue Jul 01, 2014 1:54 pm
Im with chrisearl88 - most likely a physical change related to exhaust. You may also want to check for exhaust / manifold cracks that have suddenly become more pronounced due to tune.
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
zero00
Postby zero00 » Tue Jul 01, 2014 4:07 pm
emily_mx5 wrote:It's not a carby... No such thing as a "tune"
RUBBISH!!!
Roger D-SUNSHINE COAST
speed
Postby speed » Tue Jul 01, 2014 6:09 pm
Ke? You don't believe me. Faulty sensor ran rich, new sensor not so rich. Changed sound. What's not to believe?!
lizard
Postby lizard » Tue Jul 01, 2014 6:31 pm
:roll:
OR31LLY
Postby OR31LLY » Tue Jul 01, 2014 7:03 pm
Wow didnt expect such a vast response!
I havnt got the invoice off the mech yet, as I picked it up after hours...
I most likely would assume that a air filter was replaced, as it has definately changed tone from the front section of the car.
So there wouldnt be any form of timing change from cam gears ect????
