Page 1 of 4
Gearbox oil
Posted: Tue Jun 24, 2014 1:52 pm
by vfrpete
Replaced gearbox oil, put in nulon about 300ks ago and was flat out getting it into 2nd and would crunch 3rd ( I've drĂ­ven manuals for 40 years) replaced it with Redline Mt- 90 wow what a Huge difference, very smooth changing now. Certainly recommend this oil for 6 speeds. :D
Re: Gearbox oil
Posted: Sat Jun 28, 2014 6:50 pm
by monty007
Good tip!
Re: Gearbox oil
Posted: Sat Jun 28, 2014 6:57 pm
by tescoking
Totally worth for the money, buy on ebay is even cheaper.
Re: Gearbox oil
Posted: Sat Jun 28, 2014 9:01 pm
by zossy1
Mt90 is good stuff.
Re: Gearbox oil
Posted: Sun Jun 29, 2014 10:48 pm
by smy0003
Where are you guys sourcing the redline stuff from?
Bursons?
Re: Gearbox oil
Posted: Mon Jun 30, 2014 12:37 am
by tescoking
smy0003 wrote:Where are you guys sourcing the redline stuff from?
Bursons?
local store or ebay, ebay should b cheaper
Re: Gearbox oil
Posted: Mon Jun 30, 2014 11:29 am
by 93_Clubman
Bursons?
Yeah, bought my Redline from Bursons at Carrum some years ago, but I believe it's cheaper on ebay, or from some retailers that also usually (or used to) sell on ebay:
viewtopic.php?f=29&t=45875&p=577877
Re: Gearbox oil
Posted: Tue Jul 01, 2014 10:42 pm
by vfrpete
eBay or mx5 mania
Re: Gearbox oil
Posted: Tue Jul 01, 2014 10:59 pm
by marty085
These guys used to be very cheap. Still seem to be a good price:
GL Lubricants
http://gllubricants.com/index.php?c=pro ... duct_id=89
Regents Park, Sydney. They are open 10am-4pm Monday to Saturday.
Re: Gearbox oil
Posted: Wed Jul 02, 2014 12:01 pm
by manga_blue
Harold at Performance Lube. Based in Melbourne but postage is usually cheap.
http://www.performancelub.com/Redline%20pricelist.htm
Re: Gearbox oil
Posted: Wed Jul 02, 2014 5:39 pm
by Regie
interesting, i have run the Redline previously, now run the Nulon and the gearbox has never felt better!
Re: Gearbox oil
Posted: Mon Jul 21, 2014 11:02 pm
by ED_MX5
Hey all,
I have just bought an 2000 NB 6spd.
I have changed all the oils on weekend. But I have noticed even from first picking up the car, basically impossible to change from 3 back to second when cold without a proper double clutch, even then a slight crunch. Also it is stiff and rough into third also when cold.
I am running Nulon full synthetic 75w90 with the g70 friction modifier in it.
Usually great oil as I have used I in other cars..
Problem goes away when gearbox is warm, still a touch stiff into third, but second appears to clear up.
Hope I can clear it up... BRILLIANT car otherwise. Really annoying while on warm up though.
Cheers in advance.
Re: Gearbox oil
Posted: Tue Jul 22, 2014 12:44 am
by tescoking
ED_MX5 wrote:Hey all,
Cheers in advance.
I had the same problem until I used redline.
Re: Gearbox oil
Posted: Sat Jul 26, 2014 9:01 pm
by pie5
I have 2006 NC 6 Speed and like some others have experienced the notchiness and the occasional difficulty changing gears. I tried some Penrite stuff and while it improved it I still wasn't completely happy.
The recommendation on the big forum in the US is to use the Ford Synthetic XT-M5-QS Gear Oil but it's not available locally or so I thought. After a lot of research I came across this Product from Ford Australia which matches the same WSD-M2C200-C specification as the US Ford Product. It's a 75W-90 spec so it matches the OE requirements for NC.
As the fill capacity is 2.1 litres I purchased 3 x 1 litre bottles Part No R1426 1L from Ford and completed the change today.
Initial impressions are very good, I like the smoothness and shift feel.
Time will tell if this product provides the same feel and smoothness the US sourced product is famous for.
For those who may be interested the MSDS is from Castrol. Google R1426 MSDS.
Re: Gearbox oil
Posted: Sun Jul 27, 2014 6:16 pm
by Hellmun
Amsoil MTG also works as well as the redline I found. I've used penrite, Royal purple and a castrol gearbox oil and only the Redline/Amsoil didn't cause hesitant cold shifts.
