Exhaust Heat Wrap - What are your experiences?
booki89
Postby booki89 » Fri Jun 20, 2014 10:32 pm
Was thinking about wrapping my stock headers on my NA 8
But found this article which poses some pretty interesting points.
http://www.centuryperformance.com/exhau ... t-use.html
Anybody using heatwrap on there headers care to comment?
Hellmun
Re: Exhaust Heat Wrap - What are your experiences?
Postby Hellmun » Fri Jun 20, 2014 11:09 pm
That article is using a nascar engine. High compression race motors held as constant high RPM tend to have different issues to a street mx5 so I wouldn't give it a great deal of thought. Personally I'd get my headers coated if I was going to have the headers/car for a a long time. I always planned on going turbo so I ran heat wrap which ended up being for 6 years on my racing beat headers... previous owner I bought the headers from had the same headers wrapped years as well. I never had any leaks or blown gaskets during that whole time I ran them. There were some cracks in the header when I sold them last year which had to be welded before the next owner could ceramic coated them but those headers saw race use in 2 cars over 10 years and I had no transmission exhaust mount so they had a decent weight twisting them on a LONG lever for nigh on 10 years :mrgreen:
The real considerations for you will be how long you want it to last? I re-wrapped headers 3 times in 6 years... it slowly falls apart between moisture and heat cycles. Most of the stuff has glass fiber as well which bites into your hands. You'll want some decent gloves and probably some clothing you won't mind throwing out... It's way easier to do it off the car.
Just realized I overlooked you staid stock headers, I wouldn't wrap those. The wrap would hold moisture on the header and that should accelerate corrosion ....
SuperMazdaKart
Postby SuperMazdaKart » Sat Jun 21, 2014 10:42 pm
A breathing mask should be worn as well if doing the wrapping, those glass fibers get into the air & aren't too comfy to breathe in. Eye protection wouldn't be a bad idea either.
I didn't have any particular bad experiences when I did it for my NA6. Ceramic coating would last longer in the long run so weigh but I don't know how much it costs.
taminga16
Postby taminga16 » Sun Jun 22, 2014 12:48 am
Talk to these people.
They would prefer an e-mail in the first instance. Email contact@jet-hot.com.au
JET-HOT Coatings Australia Pty. Ltd.
26 Elizabeth Street
Castlemaine 3450
Vic. Australia
Free Call: 1800 700 468
PHONE: 03 5470 6416
FAX: 03 5470 6431
Users browsing this forum: No registered users and 21 guests
