Gearbox Noises
Re: Gearbox Noises
Postby Regie » Fri Jun 06, 2014 4:33 pm
All the gear boots in good order??
Re: Gearbox Noises
Postby manga_blue » Fri Jun 06, 2014 6:17 pm
Same thing happened to me once on another car (actually a hot little Ford Anglia, so it's stretching the definition of "car" a bit). Swapped to a wooden gear knob and it transmitted so much gear noise I gave it away after a few days.
Gladiator
Re: Gearbox Noises
Postby Gladiator » Fri Jun 06, 2014 10:30 pm
I read your other post about fitting the SSK, & something about a wider notch than normal? could it be a vibration from that being sent up the shift stick & the different knob weight amplifying the sound?
