ALLOY RAD TOUCHING STUFF
narita
Postby narita » Sat May 31, 2014 10:12 pm
Yo homies,
So just wanted to check with people if anyone else has had their aftermarket thicker alloy rad vause clearance issues? Ive had mine in for a while but only recently noticed that the intake resenator makes contact with the rad hose to the thermostat and comes within a bee hand of the fan.
WINTON PB - 1:57.4000
M1474
Vehicle: ND - Turbo
Re: ALLOY RAD TOUCHING STUFF
Postby M1474 » Sat May 31, 2014 10:57 pm
Mates na8 had same issue with an ASI. He fitted slimmer rad fan and an ARC intake.
GHETTOCET
de Bounce
Postby de Bounce » Sat May 31, 2014 11:04 pm
I made a small bracket that holds the intake resonator closer to the front of the motor and further away from the fan frame.
From memory I shortened the radiator hose by 10 - 12 mm as the top radiator connector is about that distance closer towards the engine.
It still rubs very occasionally but no issue in about 3 - 4 years
Motorkhana Video
narita
Postby narita » Sat May 31, 2014 11:30 pm
Did either of you notice cooling increase or decrease afterward?
de Bounce
Postby de Bounce » Sun Jun 01, 2014 7:48 am
narita wrote:Did either of you notice cooling increase or decrease afterward?
In what way?
Thermal capacity of the cooling system or engine temperature under load?
Motorkhana Video
Users browsing this forum: No registered users and 104 guests
