Clutch install issues [NB]
dimarg
Postby dimarg » Wed May 21, 2014 12:31 am
Hi MX5 Brains Trust,
Just finished installing a 1.6ltr clutch and flywheel into my NB8A.
Started the car on the stands after putting everything back together, and there was a horrible metallic rattling noise coming from the gearbox area. When pressing the pedal in, the noise got somewhat louder but did not intensify any further as the pedal touched the floor.
We have since dropped the gearbox again, and it appears that the clutch was not disengaging, however can't seem to understand why, or what the noise was.
We noticed when comparing the 1.6 clutch and flywheel assembly to that of the 1.8, the 1.6 assembly sits roughly 1cm shallower than the 1.8. Could the thrust bearing be rattling off the end of the input shaft?
My friend and I are baffled.
Any ideas?
Giuls.
dimarg
Re: Clutch install issues [NB]
Postby dimarg » Wed May 21, 2014 12:35 am
I should also add.
After dropping the gearbox the second time, we could confirm the clutch was the right way around, all bolts had been tightened, and clutch pedal feel was perfect after being bled.
Can also confirm the clutch was aligned with alignment tool, and when starting the car in gear, drive the wheels spun no worries but rattle was still prevalent.
roket52
Postby roket52 » Wed May 21, 2014 7:52 pm
Is it an oem 1.6 flywheel or an after market super light one? Alloy or steel?
NB8B| MCA Blue 10K/7K |SE Sways| 8lb Flywheel| 4.1 LSD| Lots a Fun!
trader
Postby trader » Wed May 21, 2014 10:17 pm
I went the other way and put an SE clutch plate and flywheel into the 1.6. No dramas at all so should fit although I think the housing bolts were slightly longer.
NB SE, NA 1.8.
dimarg
Postby dimarg » Thu May 22, 2014 12:06 am
It's an alloy fidanza flywheel.
I have used the same combination of clutch and flywheel in my old na6 a few years ago with 0 issues.
roket52
Postby roket52 » Thu May 22, 2014 9:07 am
interesting. in my particular install on my NB8B i noticed that I now get a metallic resonance exhibited through the lightweight aftermarket 1.6lt (8lb) flywheel at low rpms. Some lightweight flywheels are known to exhibit noise at low and high rpms. This is because of their thinner, lightweight design. If you think about it they become almost like a cymbal from a drum kit and resonates noise from the motor. Its also possible that your are hearing noise on your NB8A version that you weren't hearing on your NA 1.6 because of a different motor design?. This is only an opinion though as your issue could be something different but I would recommend you do a bit of research on the lightweight flywheel noise as it seems fairly common on lightweight ones, especially alloy.
dimarg
Postby dimarg » Thu May 22, 2014 10:18 am
All opinions are welcome mate :)
The noise is definitely different to that of flywheel chatter. I did experience the resonance you speak of, so have a decent idea of what it sounds like.
This is more like a metal item is loose or out of position and rattling around...much louder noise.
roket52
Postby roket52 » Thu May 22, 2014 10:50 am
Exhaust brackets on the left side of gear box? This has me curious now
noobee
Postby noobee » Thu May 22, 2014 11:12 am
clutch definitely not disengaging?
Mick
dimarg
Postby dimarg » Thu May 22, 2014 1:34 pm
No issues with the exhaust bracket.
Mick, can confirm 100% clutch was NOT disengaging.
noobee
Postby noobee » Thu May 22, 2014 8:57 pm
we recently installed a new clutch in my sons car (1.8) and struck a (small) problem in figure 3 of this http://www.exedy.com.au/assets/files/te ... /TN015.pdf
we took the assembly back to the clutch shop to check and he solved it with .015'' shims then checked clamp pressure was ok.
if your new assembly is 10mm shallower you may need to move the pivot point similar to what is noted in this.
http://www.exedy.com.au/assets/files/technotes/TNN.pdf
but you would have to make sure everything else is right first,hydraulics,pedal stroke.I can recall having to do this about 25 years ago in similar circumstances,i think it was with a lightened flywheel and heavy duty clutch on a Datsun..we were sure then that we had something else wrong.we had the gearbox in and out 3 times.hopefully someone who has struck this on an mx5 will chip in soon.
Mick
dimarg
Postby dimarg » Sat May 24, 2014 9:15 am
Mick that looks brilliant! Thanks for the info.
Will try and give it a crack this weekend!
noobee
Postby noobee » Sat May 24, 2014 11:17 am
just be sure its not something else.i've probably done about 30 car (and a few motorbike) clutches in the last 40 years mostly datsuns holdens galants etc (saying that makes me feel old,lol) but only had to move pivot post twice.maybe I was just lucky,or maybe I was just blissfully ignorant!
Mick
Postby Mr Morlock » Sat May 24, 2014 11:58 am
I have done no where near 40 clutches!! If a clutch does not disengage- esp on old motorcycles it was nearly always related to the mechanism needing adjustment- same deal for brakes the free play before engagement needs to be adjusted. The ball head adj bolt on the pivot is adjustable but not sure how much effect it will have. A 10mm height diff strikes me as a lot to the std unit.
chefie
Postby chefie » Tue Jun 03, 2014 9:13 pm
recently had the same issue with a CI clutch
the shop supplied the wrong size throw out bearing and the race sat inside the fingers of the pressure plate.
the problem was with the clutch industries specs
98 NB8A Grace Green
LS 66.17,QR Club 69.27, QRSpr 63.58 SOLD
01 NB8B Grace Green
LS 64.66,QRNat 1.31.94,QR Club 65.17 QRSpr 62.36
93 NA8 Clubman
Users browsing this forum: No registered users and 50 guests
