A/C related SPLASH (not leak)
narita
Postby narita » Tue May 20, 2014 9:11 pm
Good afternoon,
for the past month or two, when using the a/c for extended periods and then taking any hard corner the poor passengers have had about a litre of water splashed onto their feet.
Now i decided to do some investigating, and removed the a/c drain hose (pictured below) to check for blockages. NONE.
I then removed the drain hose and ran the a/c, No water, not even a drop, would appear.
I purchased a roll of wire from a lovely elderly lady at home hardware (she was giving rave reviews on candy crush for ipad)
and took the internets advice and feed the wire up.
i was sure i heard what sounded like stiff leaves. but i could be and probably am wrong.
as common as issue as this seems in the states, surely some others here have encountered this issue?
advice would be appreciated :cry:
WINTON PB - 1:57.4000
narita
Re: A/C related SPLASH (not leak)
Postby narita » Thu May 22, 2014 12:39 pm
BUMP
speed
Postby speed » Fri May 23, 2014 7:18 pm
I don't have an answer for you but hopefully someone more knowledgable than me will reply soon :)
taminga16
Postby taminga16 » Fri May 23, 2014 7:50 pm
Shoot a PM to someone who has a stripped back NB, trackcar, ie; Boyracer.
Greg.
Users browsing this forum: No registered users and 122 guests
