208 - 0 - 207 - 201
208 - 0 - 207 - 201
Cold. I doubt hot is worth trying anyway.
Not good. I'm hoping it's just a stuck valve.
- Black_Penguin
Re: 208 - 0 - 207 - 201
Doesn't sound good mate, hope its a simple and cheap-ish fix.
- MrRevhead
Hopefully it is something like just a stuck or even a burnt valve.
And to think, you just completed 1800+ kms over a few days flawlessly!
Keep us updated.
Keep us updated.
One of the worst suggestions I'd ever heard came in today. Pour half a litre of oil down the spark plug hole and see how fast it rose on the dipstick.
- taminga16
I am still trying to figure how this might ever work?
- NitroDann
0 compression is a HUGE leak if its a piston it will run straight through into the sump.
- Vehicle: ND - RF
Maybe use one of these for a quick look at the piston top?
http://www.supercheapauto.com.au/online ... 1633#Cross
NitroDann wrote:0 compression is a HUGE leak if its a piston it will run straight through into the sump.
The old 0 psi piston.
Holy crap, that sucks man.
I don't have time it pull the head yet but one of the better suggestions from the locals was to rotate to TDC on the compression stroke and put air at 10-20psi down the plug hole. If it comes out the inlet then there's probably a dropped inlet valve. If it comes out the exhaust then there's probably a burnt exhaust valve. If it comes out the dipstick then there's a burnt piston.
My money is on a burnt exhaust valve. While I was trying to figure it out I tried cleaning the injectors. Number 2 injector was mostly blocked by white soft waxy stuff. The rest were OK. I think I bought bad fuel at Newcastle then drove 400kms on cruise control with that cylinder running lean.
Shoulda got a turbo in Newcastle
The reason I didn't was that I didn't want to spend my weekends trying to work out why my engine blew up.Okibi wrote:Shoulda got a turbo in Newcastle
- Vehicle: ND - RF
manga_blue wrote:The reason I didn't was that I didn't want to spend my weekends trying to work out why my engine blew up.Okibi wrote:Shoulda got a turbo in Newcastle
Yet your engine appears to have blown up anyway....... Just sayin'......
Users browsing this forum: Google [Bot] and 111 guests
