engine rocker cover leaking oil from the sides
Posted: Sat May 03, 2014 10:06 am
by Sal.kalandos
anyone know how I can fix this? and how much it would cost?
im not very good mechanically so I would need to take it to a mechanic.
i've put a pic
Re: engine rocker cover leaking oil from the sides
Posted: Sat May 03, 2014 10:41 am
by MrRevhead
Valve/Rocker cover gasket might need replacing.
Not hard to do, here is a guide if you want to attempt it yourself:
http://www.miata.net/garage/valvecover/Here's another one with larger pictures:
http://tinyurl.com/n5xxadfYou can purchase a new gasket from Mazda, MX5 Mania, MX5 Factory, Ebay etc
If you're not confident in doing it yourself, any mechanic should be able to do it. Alternatively, take it to somewhere like MX5 Factory and get them to supply and fit it.
Posted: Sat May 03, 2014 11:46 am
by sailaholic
It's about a 5 - 10 minute job. Make sure you get a genuine Mazda gasket. Most aftermarket ones leak from new.
Posted: Sat May 03, 2014 1:54 pm
by tescoking
make sure you put some red colour sticky stuff in between the gap before you put the cover back on.
Posted: Sat May 03, 2014 3:14 pm
by sailaholic
Where? The manuals only day to put it in the corners?
Posted: Sat May 03, 2014 4:39 pm
by manga_blue
Use auto RTV silicone sealant
only on the points shown.
Posted: Sat May 03, 2014 8:10 pm
by project.r.racing
sailaholic wrote:Where? The manuals only day to put it in the corners?
manga_blue wrote:Use auto RTV silicone sealant
that is from an old outdated NA6 manual. If you look at any manual from 94 onwards, you'll bee adding more sealent.
Not that the older way doesn't work. I just think mazda having failing cover seals just decided to make you add move for a extra fail safe.
Posted: Sat May 03, 2014 8:48 pm
by manga_blue
I've never seen Mazda recommend blanket bombing with silicone before. I wish it would make up its mind. This is copied from the Mazda factory NB8B workshop manual.
Posted: Sat May 03, 2014 9:11 pm
by manga_blue
Actually this is from the factory NB8A one. I'm wondering where yours came from?
