engine rocker cover leaking oil from the sides
Sal.kalandos
Postby Sal.kalandos » Sat May 03, 2014 10:06 am
anyone know how I can fix this? and how much it would cost?
im not very good mechanically so I would need to take it to a mechanic.
i've put a pic
MrRevhead
Re: engine rocker cover leaking oil from the sides
Postby MrRevhead » Sat May 03, 2014 10:41 am
Valve/Rocker cover gasket might need replacing.
Not hard to do, here is a guide if you want to attempt it yourself:
http://www.miata.net/garage/valvecover/
Here's another one with larger pictures:
http://tinyurl.com/n5xxadf
You can purchase a new gasket from Mazda, MX5 Mania, MX5 Factory, Ebay etc
If you're not confident in doing it yourself, any mechanic should be able to do it. Alternatively, take it to somewhere like MX5 Factory and get them to supply and fit it.
sailaholic
Postby sailaholic » Sat May 03, 2014 11:46 am
It's about a 5 - 10 minute job. Make sure you get a genuine Mazda gasket. Most aftermarket ones leak from new.
tescoking
Postby tescoking » Sat May 03, 2014 1:54 pm
make sure you put some red colour sticky stuff in between the gap before you put the cover back on.
My 5
sailaholic
Postby sailaholic » Sat May 03, 2014 3:14 pm
Where? The manuals only day to put it in the corners?
Postby manga_blue » Sat May 03, 2014 4:39 pm
Use auto RTV silicone sealant only on the points shown.
project.r.racing
Postby project.r.racing » Sat May 03, 2014 8:10 pm
sailaholic wrote:Where? The manuals only day to put it in the corners?
manga_blue wrote:Use auto RTV silicone sealant only on the points shown.
that is from an old outdated NA6 manual. If you look at any manual from 94 onwards, you'll bee adding more sealent.
Not that the older way doesn't work. I just think mazda having failing cover seals just decided to make you add move for a extra fail safe.
Postby manga_blue » Sat May 03, 2014 8:48 pm
I've never seen Mazda recommend blanket bombing with silicone before. I wish it would make up its mind. This is copied from the Mazda factory NB8B workshop manual.
Postby manga_blue » Sat May 03, 2014 9:11 pm
Actually this is from the factory NB8A one. I'm wondering where yours came from?
