MX5 Just died. Wont Catch.
So Ive been driving my mx5 all day and its been fine. I started the car to drive home and everything was still fine. Drove the car for a minute and it lost all power as I changed to 3rd gear. I tried turning it back on and the car just cranks.
Does anyone know where I should start?
I have a feeling something happened to the fuel system.
I cant smell any fuel when I crank the car. The tank is still half full.
Anyone in the eastern suburbs of Melbourne able to give me a hand?
- tescoking
Re: MX5 Just died. Wont Catch.
What model car?
Sent from my iPad using Tapatalk
Sorry. I shouldve stated in my opening post. Its an NA8.
There's no smoke or burning smell. It just cranks and cranks.
- Carnage
Do you have spark?
Sent from my GT-I9300 using Tapatalk
Im going to check now whether it has spark or not. Had to roll the car up a hill back to my mates house. I've got very limited tools. I'll report back soon.
So my friend doesnt have any tools so I cant trouble shoot anything. Anyone in melbourne free and willing to give a hand?
Try to rule out a couple of things, easiest is fuel pump.
In the engine bay there is a small diagnostics box passenger side wheel arch.
You can test the fuel pump by connecting a bridge wire from the TFP terminal to the GND terminal.
This directly powers the fuel pump, open the fuel filler to hear it easily, it should be a whine noise.
if no noise it indicated the pump is dead, or the connectors are too corroded to turn it on.
Also check air intake, as your symptoms sort of sound like a big air leak.
So I pulled out the battery cable before. I just reconnected it to test the fuel pump.
The car no longer cranks, but this is possibly due to a drained battery since ive tried to start it so many times.
There is a high pitch noise coming from the fuel filter when I bridged the F/P and Ground. Im going to check the air filter box now. So where to next?
- Bauer
Timing belt?
Did it sound like it was turning over fast when you were trying?
Thats my guess given that it lost power during a gear change. Take the oil cap off while you are turning it over to see if the cams are moving.
cheers
Stu
Stu
I was thinking it is the timing belt as well.
I checked the cams earlier and it was turning when I was cranking the car.
you start by joining the RACV and take it from there- that is what the vast majority of people do.
- zero00
Mr Morlock wrote:you start by joining the RACV and take it from there- that is what the vast majority of people do.
Agree MM - evil necessity
Roger D-SUNSHINE COAST
LOL that's exactly what I did this morning.
Hopefully my car will be back on the road soon.
Users browsing this forum: No registered users and 73 guests
