I had to forget something in putting the engine back. There is a single wire coming from the a/c compressor - magnetic clutch switch I assume - and I cannot see what it was connected to. The photos I took before removing the engine don't show the area.
Thanks in advance.
Tim
Air conditioning compressor question
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
- tescoking
Re: Air conditioning compressor question
Thanks for the suggestion. My problem is I cannot seet what the bullet connector went into. It must be underneath. I'll put it on ramps tomorrow and take the undertray off. I have vague memories of disconnecting it as I think it hard to pull apart. Buggered if I can see where it was though.
Tim
Tim
Found the bugger! It was the wire I had carefully marked a/c, but needed to be underneath to see.
Tim
Tim
- tescoking
