Oil filter sandwich plate 1.6
ArtyMiats
Postby ArtyMiats » Sat Jan 04, 2014 8:59 pm
Hi all, a mate of mine is going to part with his nice Defi gauges one of which includes an oil temp sensor. One problem installing this in my 92 NB is that the last time I changed the filter I saw there is some sort of brace that goes from the block to the intake manifold. This sits right up against the oil filter with no room to add the sandwich plate.
What solutions are there to fitting the plate in? Is it safe to remove this brace? Or is my only option a relocation kit? Thanks!
92 NA6
Apu
Re: Oil filter sandwich plate 1.6
Postby Apu » Sat Jan 04, 2014 9:20 pm
First time I've heard of NB having an issue with a sandwich plate. What size filter are you using?
ArtyMiats
Postby ArtyMiats » Sat Jan 04, 2014 9:32 pm
derp. I wrote NB, but it's a 92 NA. The filter i'm using is just the regular old Ryco Z79A
92 NA6
SuperMazdaKart
Postby SuperMazdaKart » Sat Jan 04, 2014 9:52 pm
Maybe try a smaller filter that still fits on?. Like the OEM Mazda ones or Ryco Z436 (which is the same physical size as the OEM Mazda).
project.r.racing
Postby project.r.racing » Mon Jan 06, 2014 9:35 am
Or dont use a sandwich plate and locate the sensor elsewhere.
ArtyMiats
Postby ArtyMiats » Mon Jan 06, 2014 1:27 pm
project.r.racing wrote:Or dont use a sandwich plate and locate the sensor elsewhere.
Any suggestions? Dont like the idea of a sump plug sensor
92 NA6
A.Chen89
Postby A.Chen89 » Mon Jan 06, 2014 4:01 pm
I've got my sensor in the sump without any issues. 1/8NPT tap and away you go!
If you get rid of it you can just put a 1/8 NPT cap to block the hole.
