mania intake requires you to be ballsy and cut a hole in the firewall.
pros: racecar like intake whirling. butt-dyno says hell yeah.
cons: cutting a hole, filter gets dirty very very quickly because the air is sucked from the "gutter" where the leaves and dust fall under the windscreen. i clean mine every 3 months and shake out debris every month.
Intakes
- NitroDann
Re: Intakes
None make more than 2-3hp on a stock car.
Keep that in mind.
Keep that in mind.
- MrRevhead
Re: Intakes
Quoted for truth.NitroDann wrote:None make more than 2-3hp on a stock car.
Keep that in mind.
Save your pennies & put it towards a good alignment. The placebo of sound will make you feel like you're accelerating faster.
Re: Intakes
Best intake for noise is ITB's
- tescoking
- Vehicle: ND - Turbo
Re: Intakes
I laughed maniacally the whole drive after installing a mania style cowl intake.
GHETTOCET
