So my car is super low and the rsr cat back hangs rather low just at the corner of the muffler.
After a few too many scrapes, I've discovered a hole at the base.
It's spluttered some water and carbon when I was doing a check up.
After the water stopped leaking from there, I could feel small bursts of air.
Hence, confirmation that there's a hole where it's been scraping.
Should I be worried about this hole apart from a bit of corrosion?
inb4; raising height tomorrow.
Hole in muffler
Hole in muffler
Re: Hole in muffler
get it welded, should be fairly cheap.
Re: Hole in muffler
welding is probably not likely to last long but in any event- weld or replace go to an exhaust shop and get your options.
