Leaks, gaskets and a rebuild.
Posted: Tue Dec 10, 2013 3:54 pm
So it turns out I have a serious leak somewhere, not entirely sure where but there is a lot of engine oil on and around the bottom of the sump. I'm guessing the head gasket has gotten itself a hole.
Last time I was doing big maintenance I discovered the engine is a replacement 1.6, not my original 1.6 - so I have no idea what maintenance has been done to it in the past or how many km's the engine itself has done (The chassis/drive train is on 193xxx). This causes headaches for myself, because I like knowing what has been done to my beast.
This is my 2nd serious oil leak, first was the valve cover gasket. I am in the mind-frame to do a 'rebuild'. I want to replace all the gaskets, timing belts, sensors and waterpump. So essentially a 100,000km service with a few extras.
Not being mechanically trained (I changed my wording from 'minded' due to the fact I can generally figure things out for myself, but I want to play it some-what-safe when it comes to the heart), I'm not entirely sure where I should start with planning this activity. I've found a few ''gasket kits'' on ebay, and will probably go down the line of purchasing one of them unless I am told otherwise to buy everything separately. Apart from the gaskets, water pump and belts - is there anything I should be looking at doing? I don't have the largest budget in the book which is my main concern, especially seeing as I don't want to let this evolve in to a larger problem. I do know my radiator + fans will need doing sometime in the future as well.
Before someone says ''Take it to someone who knows what they're doing", I would rather keep her with me and learn while I fix it/get helped. The second reason I can't, is well - a large sum of money spent on a mechanic will most likely make me single and sad.
So basically - I've gotten myself in over my head and not entirely sure what to do next.
