Cooling Pro Radiator?
omega36
Postby omega36 » Mon Dec 02, 2013 4:45 pm
Hi all,
My current OE radiator is leaking and the most readily available 'upgrade' seems to be the 42mm Cooling Pro radiator (eg: http://www.ebay.com.au/itm/Cooling-Pro- ... 221&_uhb=1 )
I have 1998 NB with AC and an JRSC (M45 with the cross-over tube) - would this radiator have enough space to fit?
I have searched and have found numerous answers, some saying it's easy to install, others saying it was a pain in the ass, I am hoping someone here may have a similar setup who could provide me with some certainty !
Thanks!
1990 Nissan Skyline R32 GT-R: forged motor, Wolf V500 ECU, twin GT2860R-5's, etc etc etc!
1998 Mazda MX-5: Supercharged by Jackson Racing >:)
16bit
Vehicle: NB8A - Supercharged
Re: Cooling Pro Radiator?
Postby 16bit » Mon Dec 02, 2013 4:59 pm
i have a nb8a with aircon (not working) and a rotrex supercharger.
its not that hard to install.
though getting the thick fan back on can be a pain with piping and if you have a thicker front sway bar like i do.
omega36
Postby omega36 » Mon Dec 02, 2013 5:12 pm
16bit wrote:i have a nb8a with aircon (not working) and a rotrex supercharger.
Thanks dude. Are there any other catches when installing? The next chance I'll get is probably on the weekend and I don't want to get caught out if there's anything else I need to have, ie. some people say that the bolts that hold the OE radiator are not long enough for the Cooling Pro radiator? Then again, only some people said this..
rascal
Postby rascal » Mon Dec 02, 2013 5:35 pm
omega36 wrote:Thanks dude. Are there any other catches when installing? The next chance I'll get is probably on the weekend and I don't want to get caught out if there's anything else I need to have, ie. some people say that the bolts that hold the OE radiator are not long enough for the Cooling Pro radiator? Then again, only some people said this..
I also fitted one to my NB8A 4 years (and 40 track days) ago.
Bolted straight in. No fitment or bolt length issues.
omega36
Postby omega36 » Mon Dec 02, 2013 5:51 pm
Thanks guys, I think I'll just go ahead and order one and will see how things go from there!
16bit
Postby 16bit » Mon Dec 02, 2013 9:00 pm
the only thing i found was the coolant change bolt was of poor quality and i snapped the wing bits on it so be careful with that.
other then that it fit pretty well.
omega36
Postby omega36 » Mon Dec 09, 2013 11:48 pm
Hi all,
Just letting you know that I fitted the 42mm Cooling Pro radiator to my MX5 tonight. It was very easy to install and everything fitted as expected :)
