Bp4w & 6 speed conversion into NA 1.6 clutch problem
Posted: Tue Nov 19, 2013 12:24 am
Gday all,
I have recently swapped my 1.6 to a bp4w 99 and 6 speed from a mazdaspeed.
car starts and runs fine however theres a problem...
I resued my 1.6 flywheel and 1.6 clutch as they were pretty much brand new.
However now the clutch fork from the 6 speed seems to have a bit of play as the pin from the slave cylinder seems a little too short.
Is this because the 1.6 pressure plate is thinner causing the fork to have more room to move. Or is it something else?
Would dropping the box and putting 1.8 clutch/fw reduce the play, bringing the fork back in line for the pin from the slave cylinder.
I resued the release bearing from the 5 speed into the 6 speed as the 6 was shot. Would this be also likely to cause an issue ? (the part numbers are the same?)
Any help would be appreciated.
Regards
Sam
Regards
Sam
