Hey all.
Just doing my rear main seal, took out the old one and noticed that it had left a groove on the crank. I've been told that this is not uncommon, and all I need to do is install the seal in a different location.
How far can I push the rear main seal in? Or should I have it sticking out 1mm?
Thanks!
Rear main seal questions
- mrpham
Current Forum Specials!
- Gladiator
Re: Rear main seal questions
I've always been lead to believe it should be flush. Don't know for sure though.
- mrpham
Thanks mate.
I've always installed rear mains flush to the edge too, but I don't know if I can in this case because of the groove worn into my crank from the previous seal. I feel that I should install the new seal in a different position so that it doesn't sit on the groove. Just not sure how deep I can install the new seal or just have it sticking out 1-2mm.
- Matt
- Learner Driver
You need a Speedi Sleeve. Some info here http://www.industrialbearings.com.au/up ... 271826.pdf
They're available at most bearing retailers for not much money.
- mrpham
Matt wrote:You need a Speedi Sleeve. Some info here http://www.industrialbearings.com.au/up ... 271826.pdf
Thanks mate! Do you know if they sleeves can be installed with crank still in the engine?
- geofiz
Yep, the sleeves can be installed in situ.
NB8A - mostly stock for now
