NA6 Fan Motor Squealing
Rovy
Postby Rovy » Fri Oct 18, 2013 12:41 pm
Hi,
The motor on my NA6 fan is squealing when it comes on. Took the fan off about 8 weeks ago and tried to lub it up. It has stayed quiet till today. I used some Teflon spray on the the shaft hoping it would flow down onto the bearings.
Is there anyway of getting lubrication into the fan bearings? Or do I just replace the fan/motor?
Thanks,
Glen
Rovy
Re: NA6 Fan Motor Squealing
Postby Rovy » Mon Feb 10, 2014 8:52 am
Problem solved.
I used some grease on the the shaft and it seems to have moved down onto the bearings.
