NB 5 speed cost and options?
- angusis2fast4u
So i was going to ask what would i expect to pay for an nb 5 speed gearbox but i will take the opportunity to make the right decision.
So i have a stock powered na6 with a new 4.3 nb lsd (stock ratio) differential but the current gearboxes synchros are going and so its time for a replacement. Is the best option the nb 5 speed for strength and ratios? Does the 6 speed ruin the na6 and not worth it unless rolling with more power?
A link to a good thread would be awesome!
~Angus
2001 Silver NB8B
Past: Grey 1990 Eunos Roadster
2001 Silver NB8B
Re: NB 5 speed cost and options?
http://www.miata.net/garage/KnowYourCar/S8_Gears.html
I have a 6 speed box and a 4.1 Torsten diff and with a stock 1.6 it is a good mix. However after the engine build I may look at a 4.3 diff to give faster acceleration as the car will not have enough power to reach the theoretical top speed of 273 kmh (RPM/gears). A 4.3 diff would allow 260 kmh
- NitroDann
I love the 4.3/6 speed combo on a gutless NA, but its a lot of work. It keeps you busy.
Thats what I like about it I guess.
- angusis2fast4u
NitroDann wrote:I love the 4.3/6 speed combo on a gutless NA, but its a lot of work. It keeps you busy.
I dont mind if it keeps me busy because well it is a drivers car.. But im just worried if it will ruin the acceleration of the car, well lack of acceleration it has
~Angus
2001 Silver NB8B
2001 Silver NB8B
Yes a gear calculator and compare, for example http://www.osella.com.au/gear-ratios.htm
- zoomzoom
- Vehicle: NA6 - Turbo
6 speed will improve acceleration, 5th gear is 1:1 (opposed to 4th being 1:1 in 5 speed) and 6thgear is actually a tad shorter than 5th in the 5 speed so highway revs with the 6 speed are slightly higher and there are now 5 gears up to 1:1 where there were previously 4, ie. 6 speed has closer ratios.
Tim
Tim
- angusis2fast4u
Magpie wrote:Yes a gear calculator and compare, for example http://www.osella.com.au/gear-ratios.htm
Thanks magpie seems probably better than the 5 speed
~Angus
2001 Silver NB8B
2001 Silver NB8B
- angusis2fast4u
zoomzoom wrote:6 speed will improve acceleration, 5th gear is 1:1 (opposed to 4th being 1:1 in 5 speed) and 6thgear is actually a tad shorter than 5th in the 5 speed so highway revs with the 6 speed are slightly higher and there are now 5 gears up to 1:1 where there were previously 4, ie. 6 speed has closer ratios.
Tim
So youre saying that the 6 speed will cruise at a higher rpm on the highway BUT it will be able to keep the revs higher so its in the usable powerband (which is important for an na6)?
~Angus
2001 Silver NB8B
2001 Silver NB8B
- zoomzoom
angusis2fast4u wrote:zoomzoom wrote:6 speed will improve acceleration, 5th gear is 1:1 (opposed to 4th being 1:1 in 5 speed) and 6thgear is actually a tad shorter than 5th in the 5 speed so highway revs with the 6 speed are slightly higher and there are now 5 gears up to 1:1 where there were previously 4, ie. 6 speed has closer ratios.
Tim
Pretty much.
5 speed top gear is 0.814 6 speed is 0.843 so the revs will be about 3.5% higher. eg 3.5% at 3000rpm = 3100rpm
Tim
Yes I agree with everything said as I did the same thing and loved the 6 speed on a NA6. Don't forget there is a massive difference in price between the two boxes.
5 speed approx $250+
6 speed approx $1100+ (if you can find one)
If money is no problem then 6 speed all the way.
UNDERSTEER is when you hit the wall with the front of the car. OVERSTEER is when you hit the wall with the rear of the car.
- angusis2fast4u
ja9 wrote:Yes I agree with everything said as I did the same thing and loved the 6 speed on a NA6. Don't forget there is a massive difference in price between the two boxes.
that's for an NB 5 speed right? (which has the stronger synchros?) can't call mx5 plus till monday so i just wanted to confirm because i thought i was up for a grand
~Angus
2001 Silver NB8B
2001 Silver NB8B
- orx626
- Vehicle: NC - Rotary
angusis2fast4u wrote:can't call mx5 plus till monday so i just wanted to confirm because i thought i was up for a grand
http://www.ebay.com.au/itm/Mazda-MX5-NB-NB8A-Bp-1-8L-5-Speed-Gearbox-Transmission-Good-Condition-Used-/281182269251?pt=AU_Car_Parts_Accessories&hash=item4177c4ef43
