Just changed to ASI 52mm, new rattle????
Posted: Wed Oct 02, 2013 11:24 pm
Sorry to be vague but i have no idea what the rattle is.
I just today put in a 52mm ASI radiator into a 90 Eunos (with aircon and p/s) on first start there was a slight rattle so before moving the car i tightened every bolt and it went away now it seems to rattle under braking (doesn't have to be hard braking) and when the clutch is in. I have just noticed the aircon hoses were very close to a pulley on the engine due to the added thickness so i have unbolted it and it is sitting away from the pulley, haven't been able to test it yet (this is all just happening now) but i wanted to come on here to ask advice:
1. Has anyone installed a thicker radiator and had a similar issue?
2. anyone installed an ASI radiator before and discovered stuff which may help this issue?
3. anyone know why something would rattle under braking and when the clutch is pushed in when i haven't touched any of that today and has been perfectly fine until now
and lastly linked to the last question
4. does the engine move forward a few MM depending on being on a hill, under braking etc (rattle seems to be louder when going downhill which would make the engine closer to aircon pipes if it moved at all.
**by rattle i mean fast tempo tapping sound**
sorry for all the questions but it's just a weird problem to diagnose
