replacing clutch slave cylinder
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Tue Sep 03, 2013 11:16 am
so my clutch slave cylinder finally went last night.
usual symptoms of clutch going to the floor, a little pumping managed to get it to work a bit but it was flocked.
I pulled over and the reservoir was almost empty so i went to the closest servo and got some brake fluid to top it up.
I managed to get home ok in the end.
however my question is should i replace the slave cylinder and rebuild the master cylinder at the same time?
I figure its worth if i am getting into it anyway.
emily_mx5
Re: replacing clutch slave cylinder
Postby emily_mx5 » Tue Sep 03, 2013 11:20 am
I replaced slave and master at the same time, as I have heard the pressure of a new master is enough to blow the old slave and vice versa.
The master is a bitch to do lol
Sent from my iPhone using Tapatalk - now Free
16bit
Postby 16bit » Tue Sep 03, 2013 11:31 am
typical, the instructions i found make it seem easy enough but thats never the case is it!
should i do one before the other or just replace them both then bleed it?
Postby Magpie » Tue Sep 03, 2013 11:33 am
PM CaptainNatefor info on slave then master issues.
The issue now could be that the master had a whole pile of gunk at the bottom and when you added more fluid it flused/forced the gunk into the seal/piston area now hence yes a rebuild on the master would be on the cards or even a replacement. Good luck.
If doing both make sure you flush/blow the lines out before refitting them as there maybe some rubbish in them.
Pamex
Postby Pamex » Tue Sep 03, 2013 11:34 am
I'd start just with the slave. When you're bleeding it, pump gently so the seals don't pop.
16bit
Postby 16bit » Tue Sep 03, 2013 11:39 am
hmmm, i might bleed the system first before replacing the bits to get rid of all the gunk then.
Postby 93_Clubman » Tue Sep 03, 2013 12:16 pm
As Pam says do slave first & worth flushing initially as you suggest. Replaced the original slave cylinder in my '93 NA8 in 2005 - master cylinder is still the original.
16bit
Postby 16bit » Tue Sep 03, 2013 12:21 pm
great so flush, replace slave, rebuild master, flush again.
aka_juffa
Postby aka_juffa » Tue Sep 03, 2013 6:05 pm
I recently bought a slave cylinder rebuild kit from MX5parts.co.uk Didn't fix the problem. Bought an aftermarket slave cylinder, still didn't fix the problem (although somewhat better now). I have a new master coming from the UK as I type this post. So far I have gone through almost 2 bottles of brake fluid...
Good luck.
J.
16bit
Postby 16bit » Tue Sep 03, 2013 6:17 pm
yeah thats why i pretty much thought it best to replace it all in one go.
unless there is a leak in a hard line?
Users browsing this forum: No registered users and 53 guests
