Cant get Reverse on 6 speed box, Help please
mx5rally
Postby mx5rally » Mon Aug 26, 2013 11:28 pm
Has anybody else had this problem before? I think it might be the reverse lock out pin that keeps spinning around on its guide within the box.
Any suggestions
Does anybody have any 6 speed parts or do I just get a complete second hand box?
Dave
Stay Sideways
16bit
Vehicle: NB8A - Supercharged
Re: Cant get Reverse on 6 speed box, Help please
Postby 16bit » Mon Aug 26, 2013 11:38 pm
i know in the 5 speed you leave it in neutral, then put it into 5th then go into reverse from there.
try that.
Beelzeboss
Postby Beelzeboss » Tue Aug 27, 2013 12:18 am
16bit wrote:i know in the 5 speed you leave it in neutral, then put it into 5th then go into reverse from there.
On my 5 speed you can't go straight from 5th to neutral, I thought thats when the lockout was active...
Is your clutch fully disengaging? That can make it extremely difficult to get into gear but especially reverse as it doesn't have synchro.
Andrew
NA-6 2.5 KL V6
http://barberprecision.com.au/
Postby Okibi » Tue Aug 27, 2013 1:26 am
Loosing reverse on the 6 speed was an issue when mechanics remove the wrong bolt from the gear box when they do an oil change.
Has anyone messed with the gearbox?
Postby Regie » Tue Aug 27, 2013 8:47 am
yeah have you had a recent oil change?
they could have pulled the wrong bolt..if so its a gearbox out job
Postby hks_kansei » Tue Aug 27, 2013 9:37 am
That's not normal, you should be able to go from any gear directly to neutral, at any time.
I go from 5th directly to neutral then 4th every time I'm slowing down from highway speeds.
Beelzeboss
Postby Beelzeboss » Tue Aug 27, 2013 10:29 am
WOOOPS, massive mistake. I meant to write I can't go from 5th straight to REVERSE
Andrew
NA-6 2.5 KL V6
16bit
Postby 16bit » Tue Aug 27, 2013 10:35 am
oh yeah, sorry i meant you go from 5th to reverse as you would from any other gear.
5th neutral then reverse.
it usually open its up for me if it gets sticky.
mx5rally
Postby mx5rally » Tue Aug 27, 2013 4:04 pm
I have got the gearbox apart at the moment and can see the reverse lock out. No it's not a problem to do with an oil change as I do that myself. The main reason I lost reverse is because I accidentally forced the shifter passed the lock out for reverse when trying to change to 6 th gear at 155 km/h
Stay Sideways
slimx
Postby slimx » Tue Sep 10, 2013 6:49 pm
is it NOT staying IN GEAR? (like if u HOLD it in REVERSE forcefully with your hand, does it work?)
^^ if this is the case, take it to a local mechanic or gearbox shop, it is an easy fix. I've SEEN IT been done before.
If it's the other way round and not going in, then unfortunately could be a number of things. Depending on how much u find the 2nd hand box for it's probably the best option. Unless you can open the box yourself etc.
