Throttle body sensor need help
tescoking
Postby tescoking » Sun Aug 25, 2013 6:12 am
Hey guys, can anyone tell me what sensor is it at the bottom of the throttle body? I believe mine has been broken, my mechanic adjusted the side of the sensor a bit for me so that my car can start in cold weather and will not stall. What is this sensor call? Is there any where I can find it, buy it, and replace it?
My 5
spikes
Re: Throttle body sensor need help
Postby spikes » Sun Aug 25, 2013 11:25 am
Idle speed control valve
emily_mx5
Postby emily_mx5 » Sun Aug 25, 2013 11:51 am
They often work poorly due to being really dirty or corroded.
Take it apart and clean it using carby/maf cleaner.
You can't really "adjust" the iscv afaik so maybe he fiddled with the tps?
Have you ever adjusted the base idle? (Sorry not sure about it on NB's)
tescoking
Postby tescoking » Sun Aug 25, 2013 4:57 pm
emily_mx5 wrote:They often work poorly due to being really dirty or corroded.
You could adjust it on the left hand side, there is a small hole, we used a screw driver to give it a quarter turn, and the rev is set about 1500r/min, so it won't stall when I start.
My 5
tescoking
Postby tescoking » Sun Aug 25, 2013 5:07 pm
Is there any way I could get a brand new one?
My 5
emily_mx5
Postby emily_mx5 » Sun Aug 25, 2013 5:17 pm
http://forum.miata.net/vb/showthread.php?t=71119
call mazda dealer, and i reckon its gonna be like $974.46 or something equally ridiculously expensive.
project.r.racing
Postby project.r.racing » Sun Aug 25, 2013 8:21 pm
ebay, wreckers etc have heaps. mazda 323s and ford lasers 96-98 use the same throttle body setup, so another option to look at.
it is a pretty common problem. lots of info on it if you search and use the term 'iac' or 'idle air control'.
tescoking
Postby tescoking » Sun Aug 25, 2013 9:23 pm
project.r.racing wrote:ebay, wreckers etc have heaps. mazda 323s and ford lasers 96-98 use the same throttle body setup, so another option to look at.
Thanks man, I will look it up now.
My 5
