Cleaning HLA's
jordy94
Cleaning HLA's
Postby jordy94 » Thu Aug 22, 2013 11:44 pm
I've got a set of HLA's which I'm trying to clean. I've read the miata.net guide, and searched heaps on how to pull the plunger from the housing. I got 2 pulled apart by using pliers on the inner lip.
But after trying the other 14, none of them are coming apart. I've tried the 'bashing with a hammer' method, but they still wont budge. I assume the clip ring is preventing it from coming out. Any other suggestions on how to get them out?
Jordan
Re: Cleaning HLA's
Postby 93_Clubman » Fri Aug 23, 2013 11:19 am
Manga Blue has had his apart to clean - hopefully he'll see this. Might be worth noting his comments about cleaning though:
manga_blue wrote:HLAs are a mechanical item. They do wear out. When they do then cleaning doesn't fix them.
viewtopic.php?f=29&t=59352&p=746814&hilit=hla+clean%2A#p746814
manga_blue wrote:I've done the HLA cleaning trick. Frankly it doesn't work as well as a good oil.
viewtopic.php?f=29&t=41116&p=529002&hilit=hla+clean%2A#p529002
Users browsing this forum: No registered users and 65 guests
