Sounds like it comes from the passenger side rear. But if it was a wheel bearing it should happen regardless of which gear I'm in yeah?
Only happens in 6th around the 100-120 mark.
Any thoughts guys
Thanks
6th gear, 100kph whoompwhoompwhoop sound?
- mx5002
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64
Marulan 47.01
Wakefield 1.09.64
Re: 6th gear, 100kph whoompwhoompwhoop sound?
Could be a slight buckle in the rim and/or incorrect balancing weights.
I had the same problem with my NA, new wheels + tyres + alignment made the noise go away. The noise only surfaced at higher speeds aswell.
