weight of rear housing with diff no driveshafts.
Posted: Wed May 15, 2013 12:38 am
by ralt
Hi.
Can anybody advise the weight of the above please.
Re: weight of rear housing with diff no driveshafts.
Posted: Wed May 15, 2013 7:48 am
by flycasta
The complete diff...... Pinion flange, cast iron front, crown wheel and pinion, torsen and rear alloy housing only???? Approx 26-30 Kgs
Just the rear alloy housing approx 5Kg's
I can tell you exactly later today unless someone else comes back to you in the mean time.
Posted: Wed May 15, 2013 7:56 am
by Tony
I recently sent a complete diff assembly that I sold and it weighed close to 45kg including the pallet.
Photo here:
viewtopic.php?f=44&t=57350I didn't weigh the pallet separately.
Posted: Wed May 15, 2013 10:44 am
by manga_blue
It's light enough to bench press and heavy enough to break a rib if it falls back down. Use a trolley back.
Posted: Wed May 15, 2013 7:07 pm
by ralt
Hi flycasta.
Could you confirm weight please.
Posted: Wed May 15, 2013 7:14 pm
by NitroDann
manga_blue wrote:It's light enough to bench press and heavy enough to break a rib if it falls back down. Use a trolley back.
Lol na6 is 14kg my memory.
well under 20 anyway. I posted a couple.
Posted: Wed May 15, 2013 8:00 pm
by chrisearl88
Have got a torsen im about to put in, would agree its
by chrisearl88
25-27kg
Posted: Wed May 15, 2013 8:11 pm
by flycasta
All the components weigh 29kgs with a type 1 torsen, might be 1kg difference to a type 2. Open diff would be approx 3kg lighter.
