does anyone know what the bearings are in the 5 speed boxes?
looking to put new bearings (particularly the front input shaft ones) in and was wondering what the proprietory NSK for example bearing numbers are?
gearbox bearings part numbers?
- Vehicle: NA6 - Turbo
- Vehicle: ND - 2
Re: gearbox bearings part numbers?
I can tell you tomorrow unless someone else can help before hand.
thanks. im in no hurry, just want to get all my ducks in a row before i pull the box
- Vehicle: ND - 2
Front gearbox seal BH1937E0
Front gearbox bearing TM306NRC3
Mainshaft pilot/input shaft neede roller K18.25X24.25X25
Mainshaft centre 63062RKBH5H2C3
Mainshaft rear TMB305LLUC3PX5
Cluster front TM2052RKBHSH2C3 ( this is a weird no. and might not be available so an equiv. might be your only chance)
Cluster centre
CENTRE W/- SPROCKET. NUPK2205S12NR
CENTRE W/O SPROCET. NUPK2205S1NR-H not sure what the difference is sorry
Cluster rear 63042RKBHSH2C3
Rear seal BH3475E0
With most of these part no.s they look to be fairly uncommon and most places wouldn't probably know what they are. If you can it would be best to take samples with you so you can compare the old with any equiv. they try to offer.
These are CBC bearings part no.s so would be best to try them but if you cant or dont want to then be careful with what you get.
Cluster centre
Rear seal BH3475E0
cheers for that. at least that gives something to google for equivalents.
thanks.
thanks.
